Mergola
- Jul 1, 2021
- W124 300E 1986
Hello there.
I bought w124 300E sedan petrol 1986 (euro) recently and inherited an electrical mess that I'm trying to sort out for couple of weeks now and at this point I'm getting frustrated.
First off, I'm getting hot air all the time regardless of what I switch on or off so that's what I started with.
I checked many forums, bought the service manual, multimeter and started with the duo valve.
Found one on the cheap , tested it and it works, in fact the old one worked too it just wasn't geting any voltage to it.
I tested pins on the climate unit connector with ignition on and was getting 4.5V on one side, and 5.4 on tghe other, that doesn't seems right to me because the duo valve needs 12V to close the hot water.
I powered the duo valve from battery and it does close, that's how I'm driving atm until I figure this out.
Next, climate control panel.
I have 3 of them so I'm guessing at least one of them should work right?
I found the little blower inside the glove box and it works, it does suck air from the roof hose that is attached to the cabin air sensor and here I encountered the first problem.
I don't know how to test that little sensor so I'm trying to buy one or two of those just in case, but I can't seems to find it anywhere in europe.
If I knew the mercedes part number of it I could look for it that way I guess.
In meantime, is there a way to test the sensor if it works?
Also, I found this part behind the glovebox:
Bosch 'Temperaturregler' (temperature regulator) 1 147 328 043, merc number 000 022 1503
I have the wiring diagram of my car but I can't find this part in it or anything AC system related for that matter :/
Can someone explain to me what's the job of this part and how to test it with multimeter please?
Further, are there any other sensors and thermostats that could be related to this issue that I could test/replace?
I'm a total novice when it comes to wirings and anything electrical so I really need some help here because if I bring the car to Merc dealer they will skin me alive, probably charge me more then I payed for the car heh, so I'm trying to at least troubleshoot the problem myself and anything else I can do to dodge a massive bill.
Thank you for reading.
