After 300,000kms of belting up and down Germany's autobahns one of my W124's has been suffering from dry/worn out ball joints. The symptoms being a bit of squeaking on full lock turns (you can almost feel it through the steering).
Now I can't spare it off the road just yet so what I did, as a temporary fix, was to call in to the chemists and pick up a small syringe kit for free! Fill one of the small syringes with a light oil and carefully inject the lube through the ball joint gaiter. I injected from the rear and in one of the folds to keep exposure of the hole to a minimum.
Now I can rest assured that I'm not likely to seize then shear a ball joint in the next few weeks whilst I work on gathering a nice set of replacement joints and wishbones.
NOW this is ONLY TEMPORARY and could help troubleshoot ball joint problems or buy some time to get organised to do the permanent fix.
