w124 blower resister location
E
etaxi
Can someone please direct me to the location of the heater blower motor resistor ,also known as a regulator on a 1994 E300 diesel. TIA.
etaxi
Do not know if your car is a 124 or a 210 if you go to this site and find your car with the first 6 numbers of the VIN , then go to heating and you will find it
http://www.detali.ru/cat/oem_mb0.asp?TP=1
Malcolm
E
etaxi
w124 blower resistor location
Thank you ,I have tried that site without any luck. My car is a W124. I have looked in both foot wells and it's not there. The blower motor has a red wire and a blue wire running directly from it to the firewall and I cannot see where it goes from there. etaxi
E
etaxi
Thank you Television for your help.I have a printout of this diagram but it does not explain the location or accessability of the resistor . I need to know where it is so i can access it to test or replace. etaxi
There are 4 resistors (Wire wound) in the box.
You could do a search of the forum there were many postings on it late last year
Malcolm
E
etaxi
I have searched . I have asked my local dealer and he doesnt know.I really need someone to tell me where the blower motor resister is located .Unfortunately those parts drawings are not accurate in this regard .They are only a guide for obtaining a part number which is incidentally 124 821 21 51. etaxi
E280T
You can find the resistor / regulator in the engine bay area underneath the blower motor, which is located underneath the window wiper / air intake area. check this link for specific guidance (even tho my 94 e280 T had slightly different rubbers it helped me a lot).
http://www.peachparts.com/Wikka/W124BlowerMotor
Doug1234
Bedfordshire uk
1997 w210 e300td
Not sure if this is any help but on my 1990 300d w124 it lurks up behind the servo towards the center area of the windscreen.
If you kneel down so you chin is almost touching the top of the front wing and then look at the panel that goes from behind servo and slopes upwards it will be visible .
If you look at the base of the windscreen then it sits about 8 inches further back if that makes sense.
Mine lives there and is held by two screws/bolts and roughly around 2 inch long and an inch high
