W124 brakes
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
I think the early 320 estates had 4-pots. Certainly they had the biggest discs apart from the E500 / E36
Most German cars of the era used 4-pots on the hi-po cars but then changed to single sliding calipers to save money
Nick Froome
www.w124.co.uk
rowland75
Without sounding daft... can you convert a non 4 pot easily?
Pete
Bolide
www.w124.co.uk
In theory, yes. As ever the devil's in the detail - are the mounting points the same, the master cylinders the same, the brake proportioning valve the same?
Nick Froome
www.w124.co.uk
kth286
E320 Coupe 95
There was never anything wrong with 124 brakes from the factory. Thay are considered to be excellent according to road tests at the time.
So, anyone having a deficiency in that area must have faults within their braking system.
Note thet over time the rear calipers tend to stick due to limited use.
and you must use original pads and discs from the dealer. Give your VIN to get the correct part.
The 4 pot front fixed calipers were for the extra weight and performance of the uprated later 320 cars.
P
PJackson
Thanks, but I need to know specific models that came with them...
rayhennig
1991 300CE-24 Sportline
4-Pot brakes
Hello,
My 1991 300CE-24 has 2 cylinders on each front.
I think all the 300-24's did and then the 320s.
500Es and E500s also has 4 up front.
What about the AMGs - I'm certain the E36 had 4 but what about the earlier 3.2/3.4 AMGs? I would imagine they'd have had 4 too.
Just my 2 cents' worth.
RayH
Legoman
yep 2 pot on mine :) same as 24v , needs some work on my car , knocking on the rear suspension , rear brakes binding , play in the steering , probably track rod , and i blew a tyre up the other day lol so need a new one.
Legoman
ok i stand corrected , did my brakes the other day , i have 4 pot calipers , total suprise but cool never the less :)
Legoman
ok did some checking up , all the 300-24v models had 4 pot calipers , so did the 3.4amg , 3.6amg and 500e , they all shared the same calipers :)
www.W140.co.uk&www.r129.co
