W124 Buying advice
Status
Not open for further replies.
smu95rp
Hi, I will be looking to replace a company car in a couple of months and am considering the W124 E-class models, probably the 3 litre turbodiesel models.
I am just wondering if anyone has one of these and could offer any advice, what to look for, what to avoid, etc. Having driven a manual one I know that I need an auto, I'm just wondering if there are any major falts to be aware of, or any good bargaining tips.
Thanks in advance for any advice.
Rich
E
echo200
Diagnostics and the 124 Series
Diagnostics on the 124 Series can be a problem.
When my SRS warning light failed to extinguish, I took my 1995 E200-124 (auto/petrol) to a normally reliable independent MB specialist who could not trace the fault. A Mercedes-Benz dealer then took three attempts to narrow down the possibilities using;
1. Star Diagnosis (standard dealer kit).
2. Analogue test.
3. Hand-held scanner.
The last of the three could not obtain a readout from the SRS control unit, so they thought that this might be the source of the problem (it wasn't).
To cut a long story short, I had to agree to have the SRS control unit replaced, because it was the only way to obtain a fixed price (£850) for the repair work. Had I not elected to accept this offer from a sympathetic dealer, I could have been looking at anywhere between £1500 and £2000, i.e. virtually a 'blank cheque'. Even so, with the diagnostic bill, the final total was nearly £1000.
When I pointed out to Mercedes-Benz U.K. that there is clearly a compatibility issue with the 124 Series and the Star Diagnosis system presently employed, they refused to accept my argument. In fact, they were about as much help as a chocolate fireguard. :evil:
Note that had my car been a 126 Series (1996 onwards), I was told that the fault would have been easier to trace.
One final point. Whilst manually checking the wiring on my car, the technician found evidence of corrosion. I think that this related to the terminals, although I?m no expert in these matters.
This is my only serious fault in 6 years of ownership. Otherwise, earlier this year, I replaced the front wings due to wheel arch corrosion. The rest of the bodywork is sound (almost looks like new!).
mjtray
Reading
I could be making a big gaff here, but I thought that the W124's were never fitted with a Turbo Diesel here in the UK and that this was mainly a US model.....the UK just having an unblown 3 litre straight 6 with @ 136bhp
Although there are W124's in the UK badged up as TD's I thought that these were the estates. ie the petrols being TE and the Diesels TD.
As I understand it the 300 and the smaller 250 five cylinders go on for absolutely ages as long as they have been serviced correctly.
My local garage services a 250 taxi with over 500,000 miles on it and its only major expense has been a gearbox overhaul.
Cheap, but slow motoring, which maybe is not such a bad thing on these camera infested roads.
smu95rp
Yeah I think you're probably right. I had misunderstood the 'T' badging. Can't imagine you'd really need a turbo with 3 litres.
The slow motoring is part of the appeal. I currently have a company Alfa 147 which eggs me on somewhat. Looking for something more relaxed that would calm my driving style down.
Thanks for your help both of you.
simon paynter
as you say no RHD 124 desiels are turboed , reason being the turbo and associated manifold would foul the steering box on a 124
I have a left hand drive 300TD Turbo 4matic this is a 4WD estate, this has the turboed 603 3 litre diesel lump and gives 146 HP according to the book and I think a fair bit more torque too
124s of the year 90 or older do develop wiring niggles, something to watch for is contacts that show a voltage across but will not pass amperage, a dry contact window switches, seat switches and the like, dismantling the switch and cleaning the contacts works
Akers Ridge
Ok...
If you wanna avoid some inconvenience:
1. Obviously, take her for a spin, preferably at night to check all lights and stuff, and it's quieter, so you can hear your car.
2. Try E V E R Y T H I N G!!
3. Check the fuse box for blown fuses.
4. check service history..
5. ....some other stuff... i forget...sorry.. :oops:
Status
www.ckinsurance.co.uk
