W124 Cabrio interior panel removal
Andedav
Aberdeen
R230 SL 500
How do you remove the rear side panel that covers the seat belt presenter? i have taken out all the visible retainer screws and the chrome plate near the door. I can get the bottom to lift but the top is 100% not moving. Do not see any visible screws.
DREAMER NO2
W124 2.6E M103 1989
free manual google this - Model 124 Maintenance Manual Index then m103 0r m104 what ever ever yours is.
Then look for page number 68 interior trim 68 - 470 saloon and coupe are in there .
Andedav
Andedav
Aberdeen
R230 SL 500
Thanks for this, finally got it off but last bit was a struggle until i finally figured it out. Thinking of making a youtube video, searched forever when i started but could not find one.
Jeff Firth
A124 Cabriolet E200
Jeff Firth
A124 Cabriolet E200
Any hints or video made? I am about to try and replace my seat belt extender on a 1996 E220 A124 Cabriolet? Cheers Jeff
Andedav
Andedav
Aberdeen
R230 SL 500
The manual Dreamer lined me up with was a big help and easy if you follow the steps. Once all the screws were out the diagram for removing the panel shows 2 arrows, slide to the right then lift. This is where i got stuck as it refused to slide. In fact it is a metal clip on the body and a bar on the panel, so when i got frustrated and gave the panel a mighty yank the panel side nearest the door lifted off, i then saw the arrangement and just worked it upwards. I did not replace the entire presenter, i got new plastic gears from germany and replaced them with the presenter in-situ.
Andedav
Andedav
Aberdeen
R230 SL 500
Video will be a winter project.
Jeff Firth
A124 Cabriolet E200
Hi There
Just started the project and sure enough cant get the rear side panel off. All is loose apart from the piece hidden by the rear seat.
I have a nasty feeling I may have to remove the seat but I cant find any bolts. ANy suggestions appreciated. Jeff
Jeff Firth
A124 Cabriolet E200
Managed to get everything off - involved removing rear seat. I then saw the seat belt returner was too difficult to remove and so I put everything back. Quite an operation. You mention you replaced the cogs - was that easy? Should the returner be making whirring noises even with the cogs not working? Mine is not. The passenger one works perfectly.
Andedav
Andedav
Aberdeen
R230 SL 500
I got the cogs from germany. Cogs were the problem with mine.you could tell it was trying to function as it was making a racket. The cogs were not difficult to replace but there is a spring arrangement holding them in and that was a real B***8 to get back in. I did it with finger power, there must be a tool to do this. If there is no noise coming from yours it something else
Andedav
Andedav
Aberdeen
R230 SL 500
Here is a real good video of how the hood works and dismantling. Just about fall asleep with the guys mono-tone
Andedav
Andedav
Aberdeen
R230 SL 500
This one shows the belt presenter dismantled at around 6 minutes in.
