quenching
- May 8, 2010
- 1984 W201, 1996 W124
My '94 E220 W124 estate has started to have central locking issues today. When opening the drivers door with the key (no remote locking) only the drivers door opens, none of the other doors or the tailgate unlock, however if I keep the key turned all the windows will lower as expected. If I open the doors from inside the car and then lock the drivers door, either with the key of by pushing the button down, then all the doors and tailgate will lock. Also if the key is kept turned then all the windows will raise.
I've changed the fuse, even though there obviously wasn't anything wrong with it! And the vacuum pump must be working if it locks the doors. A few months ago I had to swap the drivers and passengers locks around as the drivers one wouldn't turn (now the passenger one is the dead one) but its all been fine since. The car was in the garage yesterday to have the exhaust checked for leaks and they did poke around under the bonnet checking the manifold but I don't think thats likely to be related?
I'm now down to one lock that opens and having to open other doors and the tailgate from the inside, not an ideal situation obviously. Any pointers on what to check next would be very much appreciated.
