Willthechippie
- Sep 25, 2007
My 1991 300TD is not charging the battery up. There is no battery light glowing when running (working on start-up) but whilst driving the electrics all fade rapidly. i've changed the alternator with the correct exchange Bosch one (which does work, as i tested it myself), but still barely get 12V across the battery terminals (without load). i seem to have voltage from the battery to the alternator but no amps (ghost voltage) which leads me to think that there is some kind of heavy duty fuse between the battery and alternator that may have blown. Is this right? if so where is this located? or could it be something else? battery good. alternator good.
thanks
Will
thanks
Will
