W124 Coupe Heater - Help!
Mercky
Dublin, Ireland
96 W124 320 Coupe
Hi All,
Can somebody kindly give me some guidance, the heater in my 96 124 coupe is acting up and the passenger side goes cold after about 20 mins regardless of dial setting. The car has AC and this behaves the same when switched on. When I turn dial all the way up to the click or 'demist' it's fine and throws out great heat. Driver side is fine and works perfectly. I suspect that perhaps the temp sensor is gone on the passenger side and I was going to swop around the connectors to see if the fault followed. Yesterday after studying the fairly useless Haynes Manual I removed the fascia and the heater matrix panel no problem but theres a switch holding bracket behind which I cant seem to get out - I'm presuming the sensors are behind it going by the manual? Can anybody advise as to how to remove this switch holder (i dident want to force it) and am I right in terms of suspecting the sensor or could it be the dial / matrix itself or a dodgy duo valve?? Any thoughts and advice welcome.
Thanks in advance
Mercky
The duo valve sir 53
m.mycat
M
Mercky
Dublin, Ireland
96 W124 320 Coupe
Thanks Malcolm, you seem pretty confident! Can I reverse the connector to the duovalves to see if problem reverses also, I know the connector is keyed to only go in one way but if I overcame that is it a worthwhile check?
You can do that no problem,,, the center pin is common.
You can apply 12volt to each valve in turn and feel the clonk, also when working correctly you can feel the pulse from the control unit.
The output from the control puts out about 11 volt (pulsed) but it can be read on a normal meter
kth286
E320 Coupe 95
duo valve failures usually default to the 'hot' position, so I would say unlikely
to be that.
to be that.
Yes this is what has been said, but my 140 failed in the cold position, so we may have to discount that
M
Mercky
Dublin, Ireland
96 W124 320 Coupe
OK so I reversed the connector to the Duo valves and now the drivers side cools and the passenger side is correct - the exact reverse of before so its not the Duo valves!!
I presume now its either the dial control itself or a temp sensor? I was thinking as a temporary cheap fix I could, on the duo valve connector, short the wire from the good side (drivers side) to the pin on the duo valve for the passenger side so now the dial for the drivers side controls both valves and just use one dial for the present??
What heater control do you have, the switches can get dirty giving poor contact
As before the control panel gives out 0 to 11 volts, is there any voltage on the one that is not working
