Dear Forum,
I had the typical 124 problem of an always hot heater. This wonderful forum pointed me in the direction of the duovalve and associated fuse.
In my case it was corroded connections on the wiring to the duovalve and after a quick cleanup I now have hot and cold on both sides - ****** marvelous.
Now the query....
I first went to check the fuse using a 12 volt light up type tester. I checked the top and bottom and found power at both ends, however when I took out the fuse, I still had power at both ends. This strikes me as odd.
Could there be any scenario when this should happen, or does it look like a wiring bodge somewhere?
Now the query....
