W124 E200 Estate, ’96, 210K miles, always looked after, always utterly reliable. Except ……
VERY rarely – 4-5 isolated times in the past 3 years – the engine has failed to “catch” just on the key. It catches perfectly fine with a blip on the throttle at the same time and will rev fine, but come off the throttle and it dies, won’t idle. It might take just 2-3-4 turns and 10 seconds to then start normally, or might take 30-40 tries across 10-15 mins, but it has always started fine at some point soon after that initial little hiccup and settled to a smooth steady idle perfectly normally. It doesn’t ever cut out, simply doesn’t fire on the odd occasion
There has not been an obvious pattern of weather, temperature, time of year, from-cold or from-hot, etc. No other powered system has been affected/unusable that I have noticed.
Virtually impossible to catch/predict/replicate/sustain/explore.
Checked in isolation the fuel/pump/delivery/system is fine, ditto electrics/spark etc. Seemingly those two systems just occasionally don’t speak to each other except when encouraged/overridden by a tickle on the throttle, though at some point it self-corrects anyway.
It has occurred on each of the past three days however after 5-6 months clear, and is now more than an overlookable little sporadic nuisance after embarrassingly stranding me temporarily at a client’s premises.
Is this symptomatic of a known fault/failure please? If not, is anything in particular indicated? I have reached the limit of my awareness of internal combustion engine general-principles, and am still learning of M-B specific wizardry/systems. More-informed thoughts and opinions would be appreciated.
With thanks
With thanks
