Hi everybody ,
After servicing the Wiper Motor and the heater blower motor I noticed that my airconidtioning did not function . I checked and found that the compressor does not switch on . As per a friends advice , I shorted the leads on a the sensor switch(mounted on refrigerant bottle (with window) and found that this switches on the compressor but it does not get cool. The pipe leading to condensor does not get hot as it normaly should . My question is :
1 - I suspect that there is no referigerant - hence switch open circuit - I suppose to protect the compressor .Can someone please confirm that this is true ? or is it that the sensor switch has gone faulty
2 - Is it possible that a by servicing the heater blower motor, there could be something that could have gone wrong here - I mean sudden loss of refrigerant?
3 - If there is a leak what is the best method to detect it ?
Thanks in advance
Bert
Thanks in advance
Bert
