W124 E280 Oil pressure gauge
Gastro
North East Hampshire
E280 Estate W211 Sept 2007
The oil pressure gauge on my E280 (Sept '93) reads one bar of pressure as soon as the ignition is switched on. When the motor is running and idling at 750 rpm hot, the oil pressure gauge needle begins to flicker rapidly between 2 and 3 Bar. It does this in cycles for about 5 seconds every minute or so.
Am I looking at pressure sender replacement or should I suspect the gauge?
The motor has covered just over 107k miles and in my one thousand miles of ownership has used no engine oil.
Thanks for your guidance and opinions.
paulcallender
Banned
NW
I would suspect the wiring, before the sender or gauge. Its probably a bad connection on the oil pressure sender, om the engine. Check & clean the contacts and the quality of the wire, before you replace anything expensive!
