W124 E300 Diesel / S124 E300 Diesel Differential
Seweryn
Eire
Hello,
I am looking for an information if the size of the differential units in W124 E300 Diesel Saloon and in the Estate S124 E300 Diesel are the same? I know, the final drive ratio is not exactly the same, but how about the external size, fittings, etc? Are these diffs interchangeble without changing the shafts, etc? Both cars are automatic with ABS, without ASD.
Thanks.
Seweryn
Eire
As far as I know they are identical save for ratio
Nick Froome
www.w124.co.uk
Thanks Nick.
The ratio in the Saloon is 2.87 and in the Estate is 3.07 and I am looking to put the diff from a Saloon to my T, that's why I am asking.
Regards.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
The estate car easily pull a higher top gear. I had a 5-speed manual E300 Diesel for a while and 4th was about the same as top in an auto. 5th was quite a bit higher and it pulled it with no problem at all
The car will be a little slower off the line but I don't think the difference will be night & day
You'll be pulling 3740 rpm on the motorway rather than 4000 rpm
Nick Froome
www.w124.co.uk
Seweryn
Eire
That's what I am after. I am not going to pull trailers or carrying heavy stuff, but the extra 7% on the ratio would be in plus.
www.ckinsurance.co.uk
