Help ! Appreciate any guidance on problem just experienced on my '93 E300D !
What started as a minor leak, has now resulted in complete failure of pipework circulating the hydraulic fluid to the rear suspension (while I was waiting for the my local MB specialist to confirm options/solutions).
My local MB specialist has now recommended only one solution possible - i.e. replace complete pipework (front to back). I'm informed the actual MB parts are not too expensive (£269), but the sting is the labour because the rear subframe needs to be dropped to get at the pipes and replace. Estimated at 10+ hours work ! There is also no guarantee that once the work has commenced other items may be required.
The pipes (2 running in parrallel from front to back) look to be in good condition generally with only minor corrosion visible. The point of failure is a straight section where the pipes are secured to the underbody towards the back of the car. Is it possible to replace only a small section of the pipes (say 4" to 6") ?
Any other suggestions would be most welcome.
Thanks, Steve
Thanks, Steve
