M
Martin Kelly
Hi there.
I have a 1996 E320 Coupe, which I LOVE. The only weak point is suspension. 2 things :
1. Car seems to sit very high - 4inch gap from front wheel arch to top of tyre, and 3 inches on rear wheels. (I have 195x65x15 tyres). Front suspension bushing have 2 'dots'. I think changing bushings to 1 dot would make very little difference. Ideally I would like to lower fron by 1- 2 inches. Any suggestions ?
2. Also, at speed the car can become bouncy, esp in rear, and can roll quite abit. Also very sensitive to strong side winds. The shocks are all new (MB). I want to stiffen, and lower somewhat the suspension, but do not want to feel (and hear) every bump in the road - ie I don't want it too stiff. I was considering changing shocks and springs to Sportline and have the following questions :
- is Sportline too stiff ? Is there any recommended halfway house ?
- has anyone done this conversion for this car? If so, any comments / lessons? What parts are required ?
Thanks a lot.
By the way, I see some threads on W124 pulling to the left
- I had that problem, and had to send it back for wheel allignment twice, but that did the trick. It appears that this car is VERY sensitive to a) allignment settings - need to be precise, and b) road camber.
Cheers
Martin
Thanks a lot.
Cheers
Martin
