W124 E320 Fuses
shj
Advice Please,I was advised that it would be a good idea to replace all my fuses(the oblong ones) and should be Merc fuses and not the current ones from Halfords,the local Merc dealer has been trying for six months to source them,not very hard I suspect,no margin! any thoughts please as to where I might get Merc fuses.
F
FOZZY
if this will help got full set from Merc Dealer in hull westways had then in stock
The Halfords oblong fuses are OK, its the Halfords blade type that give the problems owing to undersized blades.
Malcolm
shj
Thank you both for that,I will get some new Halford ones
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
The original fuses are made from some type of ceramic and withstand heat. The cheap replacements are plastic and don't
When you get a poor connection on a W124 fuse it tends to heat up & melt the fuse or fusebox. So a good-quality, clean fuse is the best thing to have
You can clean fuse & fuseholders with Scotchbrite. Probably best to junk the fuses if you can find some good-quality replacements. If you can't, just clean them and replace them
Nick Froome
www.w124.co.uk
Nick Froome
www.w124.co.uk
Just to add to nicks super posting, do what he says,go into a tandy shop and get some non drying switch lubricant cleaner,and this will stop any moisture or arcing taking place.
Malcolm
shj
Nick,my currrent fuses are plastic,where can I get the ceramic ones ?
How about moveing your business to Glos !
For the switch liubricant try a Maplins shop or online Maplins, CPC, Farnell or RS. Tandy (Radio Shack) closed all its UK stores quite awhile ago.
