- Thread Starter
- Thread starter
- #61
Hi Tim
Yes, I thought you meant ECU! MAF is the airflow meter in air intake. Well you seem well able for the challenge. If its low power (but still able to run at 75 mph) without a misfire, I would have thought a 'mechanical' rather than an 'electrical' problem is more likely, but as you say, common logic doesn't seem to prevail anymore when diagnosing problems in cars. Most 124s I've seen DON'T have a lumpy tickover, even at 150K, so maybe this is a clue too. Can you do a compression test on each cylinder? An OVPR is about £50 I think, but not probably worth changing without more evidence, unless you can borrow one from another car to try. Check the 1 or 2 fuses on top of it are OK though.
There's quite a lot of info on this forum (and on the web generally) if you key in the right words to search for.
