EEEDELLI
Folks,
I recently acquired (was given!) a rather battered w124 230CE (G reg (90?)) as a possible second car.
When you use the foglight switch, only the front foglights come on. The rear bulb is ok. The Haynes is a bit vague about the wiring, mentioning a 'lighting control unit' which is shown in their diagrams. I need to see whether the 12v feed is coming from it to determine whether it's a wiring fault .... but where is the control unit located? (No mention in the Haynes!)
There's also a problem with the rear door windows. Both are dead. I haven't had a chance to check through yet but it's not just the child safety switch and all the fuses seem ok.
It also has a duff head gasket and, with frost on the way, I drained the radiator recently. Haynes shows another drain on the block. It appears, from the pics, to be under the exhaust manifold but I can't see it on mine. Were they always fitted with one and did it appear in different places?
Any ideas?
Regards,
D.
Any ideas?
Regards,
D.
