Wheelbarrow
- Feb 8, 2008
- Location
- West Wales
- Website
- www.gwynfor.co.uk
- 1990 230TE 254,000, Land Rover Series IIa (SORNed)
I'm posting this because my solution might just help others and I did not find it in other posts!
Just about a year ago my 1990 230TE (190,000 miles) started to hiccup every so often. It gradually got worse. Checking the various forums it appeared that it could be anything (or everything ).
First off was to check the distributor cap and rotor arm. These showed wear. They were replaced and all was well for a while. Problem came back. An independent specialist checked over the ignition and fuel injection. Spark strength was weak, and the mixture was weak (set spot on for a catalyst, my M102 engine does not have one, so he set the fuelling to the correct level) but nothing obvious causing the misfiring. It was fine for a while. Spark plugs were fine (new at last service) so I decided to change the coil next (it turned out that I actually had a 190 coil fitted instead of correct spec – this had been done by a main dealer some 10 years ago :-? following a similar problem!). With the new coil she drives much smoother and more eagerly, but after a few weeks the misfire starts again.
Ok back to forums, find OVP, fuse OK, pull relay disassemble – find dry joint. Fix. Brilliant – for a while – then misfire comes back. Fuel Pump Relay checks out ok, fuel pump is ok, fuel filter is ok. Other posts now hint at vacuum leaks, temperature sender, cold start valve or ECU. Start with the easy stuff.
I discover the area around the temperature sender, etc is a bit grimy. I clean this off with petrol (in well ventilated area!) and continue to clean whole area under the air filter while I’m at it (checking the vacuum system visually as I go).
As dirt is dislodged by the brush I notice some brown coloured wires moving. Where do these go – I check the wiring diagram. They are the earth wires for the temp sender, cold start valve and the KE-Jetronic . Wires are removed, contact surfaces cleaned and refitted (with a spring washer!). Put everything back together. That was a month ago.
No more misfires car driving like a dream .
So if anyone else is having misfires with a W124 and an M102 check for loose wiring under the air filter!
