W124 estate luggage cover
Woody121
Hi all - I have a silly problem: the spring in the luggage cover on my W124 estate has gone and it won't retract. Can anyone help? Should I just buy a replacement or can it be fixed?
Thanks - Woody
E
elkanavantage
with sympathy!
I have just posted a thread on the same problem, but on my 1999 E 320 estate. Mine retracts partially. So can only sympathise but not help. Of you get an answer and which is not "replace" wld appreciate a call. 01179099036
Same answer
These are fiddly things and not made to be repaired the ends break off the springs, some do take them apart to fix, but again not easy.
Maybe a member will come on that has managed to fix one
Peter C1974
Buckinghamshire
1985 W123 230E & 1991 W124 200E & 1999 W210 E240
There's a W124 load cover on Ebay, 1d3h to go, £9.99 + £20 p&p, no bids.
Silver 300te
EDINBURGH
300te, 1992, M103
Like chip in here with, "Oh bollocks!"
Pulled the end of mine taking it out to fit son's clobber for university.
Stevetaxi
2014 E class 250 AMG Estate
UPDATE... the locating peg wasnt going up when the button was pressed, so i did get the whole thing out, all the bits fell out the plastic end cover when i took it off, but heres the problem now, the load cover is under tension, the cover came off and ZZZZZZZZZZZ the spring unloaded
i cant work out how to tension the spring to refit the plastic end cover...
