Peter C1974
- Feb 20, 2009
- Location
- Buckinghamshire
- 1985 W123 230E & 1991 W124 200E & 1999 W210 E240
As this is my first post on this forum I will start by introducing myself. My name is Peter and a couple of weeks ago I bought a 1993 Mercedes W124 200TE, fitted with a manual gearbox. The car has covered 140k, has a FSH and the previous, elderly owner had the car for the past 9 years. In general, the car has been very well looked after.
I have noticed that the manual gearbox makes a "meshing" sound. The noise is not a whine and otherwise the 'box is in good condition, with no clonks and all gears engage smoothly.
The gearbox noise is not very loud but it is noticeable. The noise can be heard when I apply the throttle but the 'box is quiet on over run or at constant speeds.
The clutch release bearing is a little noisy (very slight) but the noise goes when the clutch pedal is depressed.
I suspect that the gearbox noise has something to do with the input shaft bearing, as the volume and sound are the same in each gear and increase with engine speed, not road speed. Or could it be the clutch bearing that is making the noise?
If it is the gearbox input shaft bearing that is noisy, would an oil change or top up improve matters?
Regards,
Peter
Regards,
Peter
