w124 gearbox rattle
shirubaby
Loughborough, UK
HI guys,
I wonder if you can hazard a guess as to what this noise might be.
I have a 300ce 1989 model (sportsline?). The autobox gives a rattle (like a spanner was dropped into it), when I start up from cold and only when I put it into Drive. ALSO the rattle can only be heard when stationary.
Once I drive away the noise goes away aswell. After a while the noise is not there even when stationary.
I am planning to change the filter and transmission oil soon...as I have a jerky engage of "drive" when I pull away.
Any advice and wisdom is appreciated greatly.
Shiru
shirubaby said:
HI guys,
Shiru
Forgive me for asking, are you sure the noise is coming from the gearbox, could it be external to the gearbox.
malcolm
shirubaby
shirubaby
Loughborough, UK
I assumed the noise is from the gearbox because it only starts when I shift the car from park to drive (when car is stationary). Do you think that it could be a external component (which is good news), such as exhaust heat shield?
shirubaby said:
cured = replaced exhaust mid section
Cheaper than the gearbox,i know its confusing sometimes.
Malcolm
Tel: 020 8863 9233
