W124 Head Light Settings
keithbradley7
HI every body happy new year :D my headlights are too low i have tried headlamp beam but it do's not work
Ellsy Tanners
Mars
There will be two adjustment screws on the top of the headlight, one adjusts left and right and the other beam up down. black plastic 10mm nuts.
If you have adjustment wheel on the dash, then you may have a vacuum leak on the system if this is not working at all.
if that dont work, you may need to strip down the headlight and check/repair the adjustment mechanism
