Noddywithout Bigears
New to the forum, so sorry if I appear rather thick.
Mercedes 230TE 1992
I have a problem with my heater (stone cold), after reading the posts regarding the duovalves I've been trying to identify exactly where the problem is. The small separate pump which is directly before the duovalves (located inside engine bay on N/S wheel arch) appears not to be working, as the hose into the pump from the water pump is warm, but the hose out of the pump into the duovalves is cold. But the rear of the pump housing is warm (I hope everybody is following this
) so my question are these;
How do I confirm that the pump has actually failed? new one £136 excluding VAT.
Is there a cheaper alternative?
P.S All fuses have been checked and replaced.
Mercedes 230TE 1992
