W124 Heater
Chippydad
Hi all. Problem with the heater, blows hot contiuesly. Control wheels are on mim. Phew!! what a scortcher.:confused:
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
Duo or mono valve defaults to open without power so check power feed to the heater system.
Geo.
C
Chippydad
Thanks chaps.....How do i find the duo valve and is it very accesable?
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
Open bonnet, look by brake servo, it's almost directly in front of driver.
You will see numerous pipes, but what you are interested in is a block connected to the pipes with what look like two silver cotton reels on it, those are the solenoid valves. Later cars also have an auxilliary electric water pump on the same block, earlier cars have it in the engine compartment near the washer bottle reservoir.
As was said, I would check for fuses....is it fully automatic ACC ? How many push buttons? 3 is conventional system, 5? I think is the more complex ACC, which can burn out and lose control of the solenoids.
Richard
C
Chippydad
Cheers, thats very helpfull. Its getting dark now ill check in the AM.
C
Chippydad
You are all super.....Fuse, in its socket it looked fine, took it out and noticed a rusty end and it then broke, replaced it with a good`en and hey presto.....cool man. OK, Halfords today not MB dealer tomorow......Cheers!
C220GJS
Shotts, Scotland.
Yippee!!, always look for the simple fix first. Fuses on these cars are a known problem area ,best to replace the lot.
Geo.:D
johnnycapone
Morecambe
I have the problem that the drivers side heater will operate ok but the passengers side will only blow cold.
Tried the simple things like giving it a thump but to no avail.
Now the weather is getting a little more clement, I might try and strip the duo valve and take a proper look.
Regards
John
C220GJS
Shotts, Scotland.
Regards
John
First, to rule out any electrical problem, unplug the duo-valve, your heating should then run hot on both sides, if not the problem is probably a seized valve.
Geo.
Richard Moakes
CL500; ML500
Geo.
Wise, simple and cheap advice.
The lost art of diagnosis, seems like most garages can't do this anymore, unless they can plug in a computer and it tells them what's wrong, then they are stumped.
Richard
Richard
So true Richard, its going to get worse with all of the new inavations waiting around the corner, if it is the duo valve, they can be purchased in the USA much cheaper than here.
Malcolm
C220GJS
Shotts, Scotland.
I'm going to the US on holiday in August,maybe we could make up a bulk order and I could bring them back as hand baggage.LOL.
Geo.:D :D :D
kanda
It is near the fuse box, You can see a hose going into it.
