W124 Intermittent Loss of Brakes
300EJP
Mercedes 300E 1990
Recently purchased a 1992 W124 300E
I was aware of the problem prior to purchase but just wondered if anyone has any thoughts to what the issue may be?
The brakes/brake pedal are currently operating normally but the previous owner has advised that on 3 separate occasions while driving the brake pedal has dropped to the floor, pumping the brake solved the issue but he took the car into a local MB specialist who changed the brake master cylinder with a genuine MB part, then a few weeks went by and the same thing happened again!
Following this he has sold the car to myself.
Any ideas on where to start with this? I don't know if it could be related but on the last MOT it has 1 advisory and that is for brake lines covered in grease or other material, could there possibly be a leak in the lines? The car doesn't appear to be loosing brake fluid but Ive not had it long enough to really monitor the level myself.
Any advice appreciated :)
star
Reading
Smart + others :)
Two things to check, sticking calliper boiling the brake fluid or check the vent hole in the resivoir cap.
300EJP
Mercedes 300E 1990
ahh ok great ill check, thank you :)
jc62b
Falkirk
C220 Coupe 2014
More importantly please do not drive the car until you get this problem solved.
