Ozymandias
- Aug 13, 2005
When our 1995 manual W124 gets warm it occasionally jumps out of 2nd gear but frequently out of 3rd. If you are on the gas (lightly/hard does not matter) the can does not jump out of gear, as soon as you let off a little and get back on it jumps out, usually in traffic. The gear selection is smooth and precise in all gears with no noises. If you press against the gear knob even lightly it does not jump out of gear. When you move off in first the car occasionally surges forward or gently kangaroos like a learner driver!. I have checked the linkages are lubed ok, took the console out to have a look and all looks and feels in order. Any thoughts or pointers please. If i could add anything else i would say that there is a little bit of backlash with the prop felt in first gear. :???:
