John Turner
- May 20, 2002
- S124 250TD (1989), S124 E300TD (1995), S211 E320 cdi Sport (2007)
I have a late E300TD W124 Estate (1995) with a 606 diesel engine and automatic transmission; the car has done 161,352 miles and has a full service history, nearly all main dealer, including the last maintenance service in December.
The car has been standing for a couple of weeks, because I have been using my other W124 (it is manual, and easier to drive up hills on snow and ice than the automatic - I live in a mountanous part of Wales). I have noticed oil on the garage floor, and tracked this to a leak at what I think is the oil pressure sensor. Facing the front of the car, the leak is on the front right hand side of the engine, on the lower part, where an electrical connection pushes onto a pin, which protrudes from a concave oval plate fixed to the oil case by two bolts. I cannot tell whether the leak is from around the pin itself, or from a gasket under the oval plate, but the concave lower edge of the plate has oil on it, suggesting from around the pin connection.
If my description is sufficient, can anyone advise whether this is a large job to fix, and if so, does the oil have to be drained?
I have of course over 7.5l of new Castrol SLX oil in the car from the recent service, so do not want to waste this! It is hard to tell how much oil is actually leaking, since it runs onto the sump guard, then dribbles out onto the garage floor. I have not yet noticed a change on the dipstick level. There is a saucer sized oil patch on newspaper after 4-5 days.
Thanks for any advice.
