W124 Rear Bushes
turnipsock
Port of Menteith
I had a look at my rear suspension as my back end seems to be getting loose. It may be my driving or the slippy roads though.
I can't see any bushes that are obviously faulty.
There is 10 bushes per side and I'm going to start replacing them. What I need to know is which ones are the more likley to wear and would give the biggest improvement if they were replaced?
turnipsock
turnipsock
Port of Menteith
I'm not sure which ones you mean. There are three arms on the front bit, I think you mean one of these, but which one? Upper, middle or lower?
(I know you told me this before, somewhere)
turnipsock
turnipsock
Port of Menteith
any idea when these were ugraded? The ones on my car look like the newer ones.
andy_k
Bexhill On Sea, East Sussex
www.ak3dgfx.com
E55 AMG
I can't answer that question but the earlier ones used hex nuts to fix them whilst the later ones have an allen key. That should help you determine which are fitted.
There's also the official "MB Bodge" - don't laugh, they welded a plate to the arms to give more rigidity but didn't change the bushes :).
Andy
turnipsock
turnipsock
Port of Menteith
There is a plate welded onto the big top one.
The arm I have on the front upper one is the same as the one on that other site, that is it has the end cutaway.
turnipsock
turnipsock
Port of Menteith
I bought a couple of new arms and the bolt kits to go with.
Bolt kit A 210 350 45 06.
Do I need a special tool for the bolts?
Why is there three bolts and two nuts?
turnipsock
turnipsock
Port of Menteith
Turnip,
if you go to hellfords, who are open late most nights, they have a torex bit that fits the bolt. I'm not sure if it's the correct thing, but it worked for me.
turnipsock
turnipsock
Port of Menteith
The new bits are a bit different to the old ones. One of the old bushes looked pretty bad. When I had this arm out, I could move the suspension around quite a bit, so I guess it takes a lot of the action.
Wonder if there is a rose joint option somewhere?
Chazchuzzlewitt
Dorchester
W/S124 320TE Estate
interesting stuff... might do this on mine in the near future- what's the special tool for that bolt with the rounded head- is it a star/torx bit or something?
turnipsock
turnipsock
Port of Menteith
Torx Bit TX55
It's not easy to get the thing into tighten the bolts up.
Also, I noticed there was evidence of corrosion on the faces of the bushes, where they connect to the chassis. I smeared on a little coppaslip when I put it all back together.
I did the other one tonight, it was in a worse state than the other one.
turnipsock
turnipsock
Port of Menteith
I haven't had a chance to try it yet. I wonder when Kimi last replaced his?
