John Turner
- May 20, 2002
- S124 250TD (1989), S124 E300TD (1995), S211 E320 cdi Sport (2007)
Can anyone advise how easy is it to remove the right rear window motor and regulator when the window is UP (and not working!) on a W124 (1989). It appaers you have to lower the window to remove the motor/regulator??Multimeter tests suggests power gets to the switch on the door panel, and electric cables seem good to motor, but I cannot get in to check live feed on motor itself. Motor was weakening and so I suspect failed motor rather than another problem.
John
John
