w124 - sloppy steering
mabbs
My 300d 1990 (137k) has, to my mind, excessive steering play, although always passed the MOT like that. Having checked the front end over, I have adjusted the end float on the front wheel bearings and replaced the centre drag link, as the n/s ball joint had play in it, which has improved steering accuracy. However the steering box seems to have a lot of play, is it possible to adjust this out, like on a Land Rover's steering box?
If so how is it done? can't see anything in the useless Haynes!
Any suggestions appreciated.
Rich
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
You can adjust the play out of the steering box but I wouldn't touch it - the problem will lie in the linkages. Sort these problems and nip up the box as a last resort. Overtightening it will create more problems than it solves
Nick Froome
www.w124.co.uk
The free play is only checked with the engine running and the wheels straight ahead, and 25mm is allowed at the wheel.
I do have a paper on setting this, but as Bolide it needs care.
philharve
Falmouth, Cornwall, United Kingdom
go.to
W202 C230K Auto 2000
Play in the drag link
Hi All
What is the effect of slight play in the drag link upon steering as speed increases? What would the driver experience?
REGARDS
Phil
Slight wandering an instability I would think
wireman
lancashire
Play in the steering of any vehicle will become more of a problem at higher speeds, an increase in vagueness/wandering being common for small amounts of play/slack degrading to downright dangerous and uncontrolable with lots of slop.
philharve
go.to
sloppy steering and vagueness
Hi Malcolm, Hi wireman
That's what I thought. Just over a week ago my C230K had its cheapest service ever following which my indie advised me about the things he found that would eventually lead to an 'advisories' at MOT time, next time or the time after that. My Merc' passed its last MOT about 7 weeks ago. So, nothing really wrong on this occasion.
However, my indie explained he had found slight play in the drag link and this got me to thinking. How long has the play be present? What did my indie do to access the degree of play? Did he apply brut force to check play?
I have mentioned several times since joining this forum that my C230K has a longstanding speed dependent problem that manifests as a steering 'vagueness' that requires frequent directional corrections to maintain a straight line. Despite receiving much advice through this forum I have never found a satisfactorily explanation. However, I wonder if after 4 1/2 years I have discovered the source of the problem?
How much play would be necessary to cause steering vagueness? I suspect it could be almost imperceptible but the effect can be quite dramatic.
REGARDS
Phil
joe1972
Manchester
I took my newly acquired 300d out for a long journey this weekend. Continuous motorway speed driving for the first time. I got some steering wander going on. Couple this to some creeking and groaning from the offside front particularly during steering at low speed....(now that the PAS fluid has been replaced and the PAS system has stopped groaning, I can hear it!!!).
I reckon I will be replacing some balljoints very soon.
Phil, this is simple to test, by just jacking say the nearside front wheel, and rocking it any play can be seen and felt, wear in the drag link will often be seen as an up and down movement. I would prefer to have no free movement
philharve
go.to
drag link play
Hi Malcolm
That would be my approach too. I am now wondering if this play has been present ever since I purchased the car four-and-a-bit years ago?
If it is the cause of the speed-related steering vagueness and I get it fixed, I should notice a big difference when I put my foot to the floor.
Is it possible that this fault has been present all this time and has only now been identified? I will be in Truro tomorrow, I will ask my indie what he did to identify the problem and what the remedy is! Are any new parts required?
REGARDS
Phil
joe1972
Manchester
There's quite a few rod ends on ebay at the moment.
Not sure if they are the right ones though.
philharve
go.to
drag link to tie bar coupling
Hi joe1972
No, my indie didn't mention rods ends ... it was the drag link coupling where it meets the tie rod. It must be a simple ball joint coupling of some description. Doesn't seem expensive or difficult to replace.
REGARDS
Phil
Well I know what a drop link is and I saw rack and pinion, and thought I was going funny in the head.
Your car must be a 202
philharve
go.to
Recirculating ball steering W202
Hi Malcolm
That's it!
If I remember correctly there are two of these links, the drag link is attached to the recirculating ball steering system; the other idler link is attached to the chassis. One end of each link attaches to the tie rod that controls the direction of the wheels.
Presumably if either of these links has wear/slack in them - 4 points in all(?) - you can get all manner of steering problems, including vagueness and abnormal tyre wear? It would seem sensible to renew all these points in a car approaching 10 year old. Or is it a case of replacing the links with new joints fitted to them?
It still doesn't look a complex or expensive job. Probably not even 1 hour.
REGARDS
Phil
You only ever have 1 as the steering box is the other, you do have track rod ends, and that is all of the steering components that wear
philharve
go.to
drag link joints
Hi Malcolm
The link in the illustration is the passive link? Its mate, the drag link, attaches to the bottom of the steering box? Both operate together, each on its own radius point to fix and limit the motion of the tie rod?
I should have thought any play in the drag link or the passive link would be readily apparent but I am wondering what kind of joints exist between the links and the tie rod? They will have to be able to rotate and therefore must wear. I wonder what condition mine are in after 120,000+ miles?
It seems to me that if any of the joints were suspect it could give rise to some interesting steering problems? The opportunity for wear must be colossal because the steering is constantly in motion?
I find it amazing that rack & pinion wasn't adopted sooner.
REGARDS
Phil
