W124 - Still cutting out when warm
howzat1976
Ealing
Old Skool
Hi Guys,
Still having problems with my E300 W124, it begins to cut out when warm. Last week I had the Dizzy cap cleaned as it was very dirty and it had moisture inside. After It started first go and now after 1/2 miles begins to "jerk". :sad:
Can this still be the problem Dizzy cap and Rotor arm needs to be changed? does this sound like symptoms of a dizzy and Rotor arm problem?
Regards
Vass
wireman
lancashire
Rotor arms can and do fail either the insulation fails to allow the sparks to dissapear to earth or the internal suppressor (if its fitted) can go open circuit and not allow them through. Distributor caps also suffer insulation problems, if they are of any great age replace them both.
Verify that water is not getting inside the distributor, whilst its in bits take a good look at any cable entry seals or the like since it should always be snuff dry inside there.
H
howzat1976
Ealing
Old Skool
Thanks Wireman, Yes I as told that there was some water inside (could be from the seal or lack of it) also was told they both looked pretty old. So I guess I should replace them both.
Would this happen when the car is warm because from cold it runs fine?
Vass
dandpl
South West France
Vass
Just check the cap again for moisture mine took three goes before it ran well and now I am replacing both cap and rotor arm.
Good luck
dandpl
H
howzat1976
Ealing
Old Skool
Good luck
dandpl
Thanks Dandpl, Your right it may need a good clean. I'll give it a go over the weekend.
I'll let you know how I get on
Regards
Vass
wireman
lancashire
If water is getting into the dizzy body it will evaporate as the engine warms so it will play up when it gets hot, check that any drainage holes are clear and make sure that water can't run in. Do not attempt to seal the dizzy completely or any water will stay in there and give trouble.
Get the engine good and hot before you dismantle the dizzy next time, leave it open for a good while this will help any trapped water dry out.
I have experienced similar intermittent faults caused by the crankshaft sensor on later bosch systems and with the hall sensor in the dizzy on older systems, maybe you have a fault outside the dizzy.
H
howzat1976
Ealing
Old Skool
Thanks, I'll try that I'm pretty sure it's the Dizzy and Rotor. 2 weeks ago it wouldn't even start then after a good clean it started 1st go. Now it plays up when warm.
Regards
Vass
