w124 suspension problem? - w124 suspension problem?
Status
Not open for further replies.
nickh
I have just bought a 1992 E230 fitted with factory sportsline suspension. The rear nearside wheel is at such an angle that the inner part of the tyre is going to wear really quickly, a quick look at the spare confirmed this..  Is this a fault or is there a simple adjustment to put this right?
DavidBlake
Hants
It can be corrected IF you have the standard Sportline set up. Take it somewhere with four wheel alignment equipment.
nickh
nickh
thanks..
Does it have to be a Mercedes dealer ? I  know our local dealer charges £90 minimum.
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
Needs to be someone who really understands Mercedes suspension geometry!  They are quite different to ordinary setups.
Go to a specialist like Andy, or stump up for the stealership to align it.  Or keep buying cheap tyres !
Richard
nickh
nickh
thanks, i guess I'll call the dealer.
Andy
West Midlands
www.mercedesservicing.com
One of the first things to make sure with your vehicle. Is that its sitting at the correct height. If the vehicle is sitting low. Then you will get excessive negative camber which will wear tyres on the inner edges. I am obviously assuming that there is no impact damage to the suspension.
Regards
Andy @ www.mercedesservicing.com
nickh
nickh
It's booked in this Friday, I guess I'll have to wait to see what the damage is :-(
nickh
nickh
FYI. It turned out to be a bent suspension arm.. Having it replaced tomorrow.
Status
www.W140.co.uk&www.r129.co
