w124 towbar
stephenson
I'd like to fit a towbar to my w124 1993 220TE 7 seater. Had a look underneath but didn't see any fixing points. Is there a plug/socket for towbar electrics? Would consider after market towbar but don't really want to make any mods to bodywork.
OlafMaxwell
Cork Ireland
W210 E320 CDI Estate
Most cars have towbar mounting points. A call to a good towbar specialist will sort it out for you. As far as I know the wiring slots in too but most towbar installers will do the wiring too. I know Merc towbar wiring now seems to come with 13 pin sockets but the adaptor from 13 to 7 pin is readily available. This alsomeans the car warning system picks up blown trailer bulbs!!
paulcallender
Banned
NW
I have a 1990 230TE with a towbar. There are no built in mounting points. The forward mounts of the towbar bolt through the floor, to a point underneath the backrest portion of the rearmost seats (and under the carpet/trim). There are 2 strengthening plates on the inside of the car. The rearmost part of the towbar bolts to a sill at the rear of the car.
The electrics, as I see it, just splice into the existing wiring in a typically amateur way.
Perhaps there are different styles of towbar, with different fittings etc. but mine seems to be a fairly simple affair.
Ian McB
Aberdeen
A Mate with a 1995 300TD has just bought a towbar from a neighbour of mine that was fitted to a 300 4-Matic estate for £25. It's a genuine MB part with the detatchable towball marked as-
ORIS 107.1270.255
Daimler Benz 1245841821
Are there different types of mountings for the 124 estate? I ask because he will be towing a 17ft caravan.The main section of the mounting is a box section that fits up and under the bumper.There are 4 bolt holes,2 each side about 3 inches apart. I would have thought that there would have been more of a framework to spread the load just as PaulCallender describes in his last posting.Sorry I don't have pics of the towbar and mountings.
If any of you chaps(or chap-esses) can shed some light on this, it would be a great help.If possible,any pics/info/specs of the different types of mountings would be brilliant. My local dealer was fine enough till I mentioned that neither the car or towbar was from themselves.
Many thanks
Ian
stephenson
Finally fitted
Bought a second hand PCT towbar from Mercland for ~ £75. On reflection it wasn't really worth it as you can get a new one for about £100 including towball, electrics and postage!
The PCT towbar has 3 mounting points. The single forward one locates in an existing large hole just forward of the petrol tank. You neet to drill up from this hole to create a hole in the floor, then fit a large bush (which came with the towbar) to take the bolt and prevent the floor and chassis being crushed together when you tighen the bolt. I gave up trying to raise the rear of the towbar to mark out the rear mounting holes, after I separated my rusty exhaust pipe from its back box!
A local garage fitted a new back box and the towbar. They stated that when I needed to replace the exhaust in the future the towbar would need to be removed!
I still needed to fit the electrics myself which meant a visit to Halfords to buy some cable, connectors and a relay!
