e36bob
- Aug 27, 2004
- Location
- Reading berkshire
- 1995 e36 amg
My 1989 W124 estate is fitted with dual air con.
The control unit has dual temperature thumbwheels, air flow direction and blower turn switches inside those, and three vertical switches in the centre of the panel.
My unit will not control the air temperature on either side, and is stuck on hot.
When the air con switch is pressed, nothing appears to happen, but the recirculation air works. This is the only way I can cool the cabin.
The air direction dial works fine, as does the blower fan, although slightly noisy.
The left hand thumbwheel has a broken output shaft going into the rheostat on the circuit board.
I am trying to find a replacement control panel to see if that works.
According to haines, my system is from Valeo.
Does anyone know where the dual cabin air temperature sensors are fitted?
Haines only gives the unit fitted to the interior cabin light unit, I presume this is for the mono system only.
Where are the relays situated?
I have seen similiar dual controls on the 300 and 500 series.but finding a reasonably cheap unit is proving difficult. mercedes quote 350+ ouch!!!
Thanks for any advice.
Bob
Bob
