Hibbo
Hi to everyone, I'm wasting no time and converting my xmas pressie (from myself) to run on veg oil.
It's a '94 E300D estate with the om606 multivalve engine.
I've attached a very badly drawn (I thought computers were meant to make things like that easier!) of my planned conversion. The black bits are what is already on the car, red bits I will be adding.
When the car is started from cold, the selector valve at the mechanical lift pump outlet will be directing the veg oil straight back to the tank. The electric pump will run, supplying derv to the IP, via seperate (additional) filters. The return line selector will direct the fuel back to the derv tank.
When the engine is up to temperature, both selectors will switch over and the electric pump will stop. Thus heated veggie will be supplied to the IP and returned to the main (veggie) tank. The NRV will stop any veg working its way back through the derv pump and lines.
At the end of the journey (if the engine will be left to cool) I will switch back to derv to purge the IP and injector lines/injectors of veg for the next cold start. If I am using two seperate selector valves then I will delay the switching of the return line for however long it takes for the IP to be purged of veg, to avoid veg ending up in the derv tank. However if I end up using a 'six port' valve then this is not possible as both valves are driven by the same motor. I do not think the IP holds that much fuel anyway.
Can anyone see any major flaws in my plan? I have not yet thought about the logistics of where to fit my extra tank yet, but want a general plan in my head before I attack the car.
Does anyone know what pressure the standard lift pump produces? What electirc pump would be suitable for me to use to provide the derv?
One potential issue would be that the (mechanical) lift pump will be trying to suck cold veggie through the standard I/D fuel lines on cold mornings. It will only be pumping it back to the tank so is not an issue in that way, but would it damage the lift pump itself?
Any advice/criticism is more than welcome!
