d215yq
- Mar 28, 2008
- Age
- 40
- Location
- Valencia, Spain
- 1987 W124 300D 280k miles
hey all,
The left front water drain pipe (the one that takes the water from the windscreen drain to the bottom of the car just behind the front left wheel) is blocked. It is blocked at the bottom and therefore can't be unblocked by coathanger/wire etc...and i can't see where the drain hole comes under the car (it dribbles out by a plastic trim piece bolted on) so can't unblock it from underneath.
Is it acceptable to use standard drain unblocking liquids i've used successfully on normal plug holes/showers, etc with good results or is there a better/more successful way to unblock it?
TIA, Ben
TIA, Ben
