W124s and sound
telletubby
between Caen and Cherbourg, Normandy
1998 W140 S320 blue
As previous posts show I'm finding it hard to wean myself from 124s. But as someone who likes to keep cars fairly original but also likes music to drive by I was wondering if anyone has managed to improve the speaker arrangement in a 124 without massacring the body and trim too much. Mine's an estate so its even worse and I've blown those ****y little dashboard speakers several times.
My simple equipment is a period MB cassette radio with CD changer under the boot floor.
Sadly cant be done, if you do a search someone fitted some reasonable speakers recently,but of the original size.
Malcolm
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
There's lots of info on this in the forum if you do a search
Some people have persuaded standard 5" (13 cm) speakers to fit in the dash but it's hard work and it's a difficult space to work in. Whatever you fit I'd roll off the bass to them and use a separate subwoofer. It's the bass that kills small full-range units - roll them off somwhere between 80 and 250 Hz using an electronic crossover with a steep slope and they'll handle quite a lot of power if they're a quality speaker
You can put tweeters in the triangular trim in the corner of the door - that works quite well
The best solution is probably door builds in the front bottom of the door. Lots of work, though
You'll find lots of ideas, including photos of a few W124 setups, at
http://www.talkaudio.co.uk/vbb/
This thread has some useful photos of dash speakers in a W124 coupe
http://www.talkaudio.co.uk/vbb/showthread.php?t=153086&highlight=w124
Nick Froome
www.w124.co.uk
stumpy
various
I have some uprated front dash speakers, speakers in the bootlid, a sub in the boot all being run by a dirty big amp. It's not the best but it is good enough.
clk200
London
www.synergy-motors.com
w124 E320\E36
It can be done, but its all down to budget. I have a set of custom door pods made for my CE, I now have a set of Focal Utopia 3 way components in the car. the Doors house a pair of 6.5" mid bss drivers at the bottom, the dash houses the 4" mid ranges and I also had tweeter pods made to do at the pos of the door, see below.
A setup like this would need to be powered using an external amp.
