Chris560SEC
- Aug 5, 2006
- Location
- East Sussex
- Website
- www.friendinthekitchen.co.uk
I have a fault with the ABS on my 560SEC.
Let me describe the fault in detail.
When starting the car and moving off you can feel the abs pulsating through the pedal at light brake pressure applications. I can feel some resistance to the pedal that I "push" through to activate the brakes efficiently. This happens until you reach 30mph when the ABS light comes on and the normal feel returns to the brake pedal.
The car has been looked at by two auto electricians. The first replaced the rear abs sensor as it was "reading low voltage". The second hooked up the system to an oscilloscope and tested each unit in turn. The voltage readings were fine, however he was only checking at low speed as he hand rotated the wheels.
I had hoped the auto electrician would read off the pins on the abs ecu to see what was happening but it seems the data for this age of car is hard to come by.
The auto electician cleaned each unit but could not remove the O/S/F as it would not budge and he feared it may break.
Short of replacing the front sensors at £80 each, do I have a diy solution that I can consider to get my abs working and the MOT passed!
I have a good understanding of the car but little hands on experience as it is normally so damn reliable. 30k miles in the last twelve months.
Thanks for your help
