Fast_Lane_Dane
- Mar 31, 2006
- Location
- Denmark
- W126 300SE 1986, M103 180 hp cat.
Hi, I have a less-than-a-year-old 100Ah VARTA battery in my 380SE. Problem is that the battery looses power overnight.
Symptom: Lights in instrument cluster etc. comes on ok, but the starter turns slowly, only a rev or two and then – dead
When recharged, it’ll hold power for a week or 2 and then the problem returns. I have suspected the auto-aerial, but that doesn’t seem to be the problem, motor in aerial stops once the antenna is retracted into the housing. The central vacuum locking pump works ok too, no leaky door cylinders, and the pump is stopped anyway approx. 30 sec by a relay.
Acc. to an electrician, I can’t use a tong amperemeter (not sure if this is what it’s called in English), since you only can use this for AC, not DC.
Where do I get started? Is there a common known problem for this, or will I need to pull every fuse out and measure if there’s consumption when the engine is turned off (hope not).
Best regards,
Hans, DK
Best regards,
Hans, DK
