sailor
Hi everyone
Have just completed registration, this is the first time I have used the forum (any forum come to think of it) and would value your advice on a problem relating to my 1989 500SEL.
A couple of days ago whilst movinging in typical town traffic I was caught unawares (panic) when my brake pedal travelled almost to the floor when applied before the brakes operated.
At the first opportunity I pulled into a side road and parked up with the engine running.
I tested the pedal again, excessive travel still present and a definate whosshing sound accompanied pedal depression.
Tried turning off engine for a couple of minutes and lifted bonnet to check fluid level which was OK.
Restarted engine but no change so drove back home carefully.
Restarted car an hour later, pedal felt fine (minimum play, hard when operated) completed short trip around the block, brakes perfoming OK.
My initial diagnosis was a 'brake servo' fault which corrected itself.
Grateful for any help please.
