W126 Viscous fan
Status
Not open for further replies.
matsmith
300ce 1990 3.0
Please excuse my ignorance but this is the first car I have had with a viscous fan! Are they ment to spin when cold or should it only engage when hot.
When I run my 1984 280SE the fan is spinning all the time! If this is normal how does the fan improve cooling when hot? Does it spin faster?
I would be grateful for your feedback.
thanks
Francois
This fan should spin all the time. You will find that if your car engine is cold, you could freely spin the fan with your hand. (When engine is off!)
Let the engine warm up and switch it off and immediatedly try spinning the fan with your hand. If will feel much stiffer.
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Used to confuse me as well but as well but then tried what Francois suggested and I saw the light.
Regards
Mike
You ever get that idle problem sorted Francois?
M
matsmith
300ce 1990 3.0
Thanks. I did the test and it all seems fine.
Francois
Mike,
On the idling problem. Not yet. I don't have much time to spend on this, so it is propably going to take a while still.
I'll post something when it is sorted.
Status
