w140 offside rear door will not unlock
LAWTONC
driver's side rear door will not open. Central locking seems to work(button rises) but will not open. Could it be soft close mechanism? Anyone know a fix please?
jibcl500
Cambridgeshire
CL500,ML55,SLK280
From the out side or inside???? check the child lock isnt activated, either on the center console switch or the door itself.
Soft closure, the main pump is under the rear seat drivers side.
jib
We do need to know if it will not open from the outside as well
L
LAWTONC
Inside And Outside! Both Handles Operate Smoothly With No Clunks(or Effect!!!); Central Locking Button Comes Up And Down Via Key Fob And Key;
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Rear seatbelt not trapped in the door anywhere is it. When you pull the internal door handle does it feel the same as the other rear door??
jib
L
LAWTONC
will check and come back thanks for the patience!
derek verney
derek verney door stuck
any luck solving, I have same problem ??? any help please....:-(
derek verney
Hi lawtonic. read your problem, have you solved it, I have same,handles work in and out, lock button works up and down via remote, all other doors fine, asked but vague answers suggesting strip rear seats etc to get doo panel off and disengage from inside ? any advise you,ve been passed on would appreciate, thanking you,
100%Bitch
Norfolk 'n' good
Probably just realised it's a coupe. ;)
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Hope not, supplied the chap with a new engine harness, would like to know how things are going.
jib
