W140 S500
Baracuddda
Twickenham UK
Hello
I hope you can help
I have a 1994 s500 coupe and although the central locking works fine drivers door button tries to pop up but does not quite manage it and I have to open the door with the key. However central locking closes everything fine ? I have sprayed some degreasing fluid and it worked for a while. I was away for three weeks and when I came once again the button would not pop up. All I can say is that it tries to pop up.
Bara
jibcl500
Cambridgeshire
CL500,ML55,SLK280
You will need to remove the door card, all the linkages will need to be clean and lubricated that should sort it, dont ask me how to remove the door card as Ive looked but always decided not to.
jib
