W163 Abs Problem
noliveira
Hi all,
I've got a problem, maybe anyone can advise me.
The ABS light doesn't turn on with the key on the ignition before start the engine.
Is there an ABS pump malfunction? Or can be only the relay?
Hello and welcome, what 163 is it.
N
noliveira
W163
MY CAR IS A ML270 FROM 2000 YEAR
Do you know what can be?
If the lamp never comes on, it could just be a simple lamp failure
N
noliveira
Thanks, I cheked and I descovered that someone has turn off the lamp (the previous owner), and now is allways on, indicating an abs fault. Where I can start to look?
There are no ABS faults listed, are you sure that it is not the BAS lamp that is alight
BlackC55
South coast
C43
The abs loom can rub through on the chassis rail at the rear on both sides. Very typical on ML's and easy to check by removing the wheel and tracing the loom back from the wheel speed sensor.
www.ckinsurance.co.uk
