W163 ML270 2002 722.6 won't engage any gears!
Blueyes1971
Blueyes1971
Midlands
2002 ML270 CDI Facelift
  • #243
SUCCESS!!!!.... she's alive.
Silently and no notice what so ever that its chosen a gear... always clonked in gear a tiny bit... can't detect it selecting now at all... for moment I thought it was still not selecting until I released the brake.
Now that's a result.
I've only put 5 litres in at the moment and still getting air out of coolant but it's looking good.
Will report back soon and hopefully put this thread to bed.
Watch this space
Watch this space
Aaaaaand Success here as well , everything is uncrossed now ;) . Well done , now get cleaning that floor indoors :D .
Blueyes1971
Blueyes1971
Midlands
  • #248
She ran faultlessly all the way to Oxford ... although after she's warm she's never liked to kick down for some time now... I'm going to start a new thread soon on installing a new turbo cartridge and actuator ... may as well replace the Maf sensor while I'm at it... I'll report after the round trip is complete ... looking all good so far
oigle
members.optusnet.com.au
So Ian mine is correct?
It cycles coolant around the trans case by ways of a gallery instead of cycling the trans fluid through the cooler?
Yes, yours is correct and normal. The coolant circulates through a heat exchanger on the side of the block and engine oil and auto tranny fluid also circulate through the unit. The unit is supposed to equalise all these temps. Doesn't do a great job. I was getting blackened and smelly auto fluid when towing in hot conditions and also the box would not change up to higher gears after a longish uphill pull - oil was too hot and ecu decided to keep it in a lower gear to increase circulation through the cooler.
I inserted a proper oil cooler into the circuit and all the issues went away.
Remember though that I do work in hotter conditions than England.
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
Really good news, a victory for determination and unwillingness to give up.
Very well done sir, its been a pleasure to follow this story.
Well done! Not many would have the courage and conviction to do what you did.
Blueyes1971
Blueyes1971
Midlands
  • #252
Cheers Kiwi
Well the courage is heavily supported by you guys also though
Blueyes1971
Blueyes1971
Midlands
  • #253
Thanks Richard.. for the kind comments and support..
Excellent work Blueyes , I look forward to the turbo thread next .
Arudge
Cradley Heath
CLK200 2000 Kompressor
I'm so pleased that this has all worked out for you, i expect it's been quite an education but one worth while.
He who never made any mistakes never did anything.
We'll done for sticking with it and thanks for giving us the story warts and all, not just the glossy bits.
I think a celebratory pint is required.
Cheers.
Blueyes1971
Blueyes1971
Midlands
  • #258
Chee
Cheers.
Cheers Andy.. really appreciated your input right from page 1... along with Steve for pointing to the right component etc.. and of course Kiwi too... all involved I thank you for your time and support .. next thread will be either Injector blowing repair / thread insert upgrade install... or turbo and actuator overhaul / recondition.
Hopefully have as much interest in those threads too.
In closing just come back from Oxford back to Hinckley.. round trip I guess around 130 ish miles with no issues and no leaks at all... I will be replacing the kick down switch in the coming thread also as a consumable due to it not working all the time but that could be due to my turbo issues .. so gonna swap it out anyway... I will document that in the coming threads... thanks again all.
All The Best
steveq
Dublin
Really well done.
I have been avidly reading each instalment. I admire your tenacity and drive (and your wife's understanding nature !!).
Inspirational.
Congratulations.
Blueyes1971
Blueyes1971
Midlands
  • #260
Really well done.
Inspirational.
Congratulations.
Thanks Steve... it's really not hard, only the will required and a few tools.
I never really understood why garages sent gearboxes out to 'Specialist' transmission firms.. and why repairing them cost considerably more than engine repairs.. non of this is rocket science to be fair.
Even when the transmission internals appear to be part of extraterrestrial anti grav propulsion.. they are not.
Google..YouTube and this forum are your friend.. thanks again
