W163 won't rev
Mark A
Aberdeen
58 ML-320CDI.
I had to drive the wifes 02 ML-270 CDI the other day, and noticed that it couldn't pull the skin off a custard (won't rev past +/- 2500rpm).
When I challenged the wife, she said that every time it comes back from our local garage (indie) it does the same and then clears. I was suspecting an issue with the MAF. If I unplug this, will it prove if it is working properly or not ?
How much for a genuine MB replacement ?
Any other likely causes.
Cheers,
Mark
Ellsy Tanners
Mars
Either a boost problem (turbo) or a throttle problem, Are you getting full throttle at the throttle acuator next to the coolant expansion tank, as i have seen loads of broken throttle cables on the ml's.
M
Mark A
Aberdeen
58 ML-320CDI.
Many thanks. I will have a look when I get home this evening, but it does seem to respond to any throttle pedal movement quickly. It just won't go past 3,000 rpm when in P or N, and when on the road, it won't go past 2,500.
Mark
M
Mark A
Aberdeen
58 ML-320CDI.
I have tried disconnecting the MAF and this made no difference. Throttle cable looks fine.
Any other ideas ?
