airbag
I wanted to ask advice to troubleshoot and fix a rear Tailgate issue on a 2010 ML 350.
Boot started to only open to halfway about 6 months back.
I had to open and close it manually to use the thing, and now its got to a stage where the remote will pop the lock, but not lift the tailgate at all. If it is manually opened to the top it will not close either.
If it is manually pushed closed the lock will engage and lock the boot correctly.
I had also noticed (when the boot was working correctly) that I could manually push the tailgate a few inches higher once the motor had fully opened it.. not sure weather that is related at all.
But what I do suspect is the car has suffered from a leaking boot since new (drips out of the plastic trim at the top left of the bootlid (where the trim joins together) and upon removing the spare wheel and looking at the motor underneath on the right side, it is showing signs of corrosion from water damage.
Is this a problem others have experienced, and could anyone advise on further tests I could try... or from the information given above diagnose?
Many thanks for your time and expertise.
