Richard Moakes
- May 19, 2002
- Location
- Newton Abbot, Devon, UK
- CL500; ML500
Took the ML out for an airing today, all seemed fine until on the way home when I couldn’t avoid one the gazillions of potholes in our roads, no immediate problem, but shortly afterwards the one of the front brakes starts to squeal. Got home to find that wheel extremely hot and assumed it must be the brakes sticking.
Removed the pads, pushed back the pistons with no problem, everything was a little crusty as you might expect but cleaned everything up, lubricated all the sliding elements with plastilube, the sliding pins were dirty but definitely not seized. Put everything back together and the caliper was sliding freely until I took up the slack by pressing the brake pedal.
Took it out again, brakes pulled up evenly, thought I must have got it, but that wheel is still getting much hotter >100degC vs. 40degC than the opposite side, so I think there must be another issue.
The pads were nice and evenly worn, no excessive dust or glazing, so it started me wondering if the pothole had damaged the wheel bearing, it’s not excessively noisy but then again W164 is always a bit noisy so hard to tell. Can’t spin the wheel freely with it being 4x4 so not easy to spin the hub and listen.
Only other thing I can think is that a month ago it had the brake booster replaced under recall, could something have gone wrong there? I don’t see how it could?
Any thoughts or things to check would be much appreciated before I fire the parts cannon.
